Forum Help & Suggestion Center This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself.
Problems with my RR 1999: 4.0L
Old Mar 18, 2016 | 09:36 PM
supercharged100's Avatar
7th Gear
Default Problems with my RR 1999: 4.0L
I am new in this forum and I really need help with my car, I am driving Range Rover 1999 – 4.0 L and below is my serious problem with my car and I would like to fix them… I love this car even though is very old:
1.)Back wiper works but, the nozzle WON’T SPRAY WATER.
2.)Key problems: won’t open the doors from far also, trigger alarm and LOCKED THE ENGINE. I put in the car starter, wouldn’t work car won’t stop (I took it out).
3.)Dash board lights are dead… ONLY THE ODOMETER (YOU CAN NOT SEE THE NUMBERS/MILES)
4.)Water problems: water gets in the car sides all the way down in the floor… I changed the sunroof the whole panel and cleaned the 4 drains AFTER CAR WASH AND HEAVY RAIN WATER ON THE FLOORS: ONLY FRONT DRIVER’S AND PASSENGER.
5.) Any opinion on leather repair?
Thank you all for your help.
Joseph. RR 1999 - 4.0 L.
Old Mar 29, 2016 | 01:02 PM
BritishautoworksSD's Avatar
Any luck with this list? Let me know
Old Mar 29, 2016 | 03:24 PM
mollusc's Avatar
You're not likely to get any responses in this section. Its description: "This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself."
Old Apr 1, 2016 | 02:05 AM
7th Gear
Default no luck... any help?
No luck at all. Any help will be great thanks. I am new to the forum and I have no clue where to start?
Old Apr 1, 2016 | 07:07 AM
mollusc's Avatar
Go back to the forum home page and post your questions in the Range Rover forum: Range Rover - Land Rover Forums - Land Rover Enthusiast Forum
Old Apr 1, 2016 | 11:47 AM
2.) This sounds like a driver's door latch is not working correctly or the engine control unit has lost synchronization with the immobilization control unit. Do you know if the engine management is a Bosch or GEMS? Most likely the door latch is the problem especially if the remote is not working correctly.
Old Apr 4, 2016 | 03:45 PM
7th Gear
That make sense, I did replaced the door latch... the engine is Bosch... was I supposed to do something else (any details will be great) thank you.
todd0765
Aug 20, 2012 09:19 PM
nmaggie98
Feb 28, 2010 10:55 AM
howsonj
Apr 17, 2009 12:55 AM
mgabriel
Feb 15, 2009 05:03 PM
red rockett
Sep 4, 2008 01:27 AM
