Freelander Talk about the Land Rover Freelander within.
05 freelander code help.
Old Nov 5, 2012 | 08:23 PM
rmrediker's Avatar
Exclamation 05 freelander code HELP!
Hello, Im new here and also new to Land Rover forums. I recently bought an 2005 Freelander with about 110,000 miles on it (private party). It had always been dealer maintained and had a clean Carfax.
About 300 miles later and the Freelander is now a so called lawn ornament. Service engine and Service engine soon lights came on, will start but when you give it gas it doesn't move even when you rev the engine
From my personal mechanic: Coolant is leaking into the valley pan or the block?.
Codes:
P1628
P1629
P2073
P0102
P1478
I would be really grateful for any helpful comments as I am not sure what these codes really mean.
Thank You
Old Nov 6, 2012 | 12:44 AM
1628 ECM, throttle monitoring/ selftest PWM signal 1 duty cycle threshold exceeded for <1 second Yes No B
1629 ECM, throttle monitoring/ self test PWM signal 2 duty cycle
threshold exceeded for >1 second Yes Yes B
P2073 did not find
0102 MAF sensor signal Short circuit to earth Yes No A
P1478 did not find, may be electronic throttle related.
The Yes No A is MIL light on, service engine soon light on, drive cycle.
Attached are pages from the RAVE shop manual that cover that. You and your mechanic should have the entire RAVE download.
Sounds like you have some cable problems and perhaps a bad electronic throttle.
File Type: pdf
Old Nov 6, 2012 | 09:06 AM
rmrediker's Avatar
Thank you very much!
I will have my mechanic take a look at it.
mpompliano
Freelander
Jan 11, 2013 07:19 PM
sayeedA
Nov 15, 2011 11:02 PM
team_lunatics
Freelander
Sep 24, 2010 12:08 PM
dleifr
Apr 12, 2009 12:16 AM
sph1nxx
Audio/Visual Electronics
Dec 26, 2007 11:54 AM
