Freelander Talk about the Land Rover Freelander within.
freelander doing my swede in!
Old Aug 19, 2017 | 04:41 AM
dtbomber74's Avatar
Exclamation freelander doing my swede in!
hi all!
i recently bought a freelander 1.8, and after a faultless first trip from Runcorn to Newark , it decided it had had enough later that same day and ground to a halt . it turned out to be a faulty fuel pump . new pump fitted, running fine....for a day. now when i accelerate it will misfire, usually aound 2-3000rpm. i then changed the plugs and map sensor, but still the persists. as it only happens around that rev range, i cant seem to work out what the problem is. so i thought i would throw the problem out there for any and every bit of advice.
also, the idle control valve clicks intermittently when the ignition is on, could this cause the problem?
thank you in advance
Brokenrover
Dec 22, 2007 02:11 PM
Brad S1
Jun 8, 2007 05:41 PM
tobob1
Oct 3, 2006 11:37 AM
rovergirl79
Apr 26, 2006 04:07 AM
Doral300sc
Feb 25, 2006 11:32 PM
