Freelander Talk about the Land Rover Freelander within.
Freelander KV6 misfire
Old Jan 11, 2008 | 03:25 PM
Savannah's Avatar
Default Freelander KV6 misfire
Have a 2001 KV6 Petrol Freelander with a persistant misfire.Launch scanner reads"misfire detected cylinder no2".Fitted new sparkplugs,swopped the coils,fitted new injector no2 cylinder,changed the petrol filter and had the petrolpump tested.Fault stays at no2.Fault only come up when check engine light comes on driving uphill.Any help will be appreciated.
Regards
Marius.
Old Jan 11, 2008 | 07:26 PM
sideburns's Avatar
Default RE: Freelander KV6 misfire
did you check fuel air spark compression...likely a loose sleeve,is it eating coolant?
ezadda
May 6, 2015 07:02 AM
Frenel
Freelander
Jul 21, 2014 09:42 AM
Maniac_Mechanic
Aug 27, 2012 11:51 PM
mougly
Freelander
Jun 11, 2012 10:07 AM
bburke
Freelander
Jun 7, 2010 12:41 PM
