Freelander Talk about the Land Rover Freelander within.
Freelander wont start
Old Dec 7, 2012 | 01:43 AM
PaulEWu's Avatar
Default Freelander wont start
I am stumped as to why this Freelander wont start. Ill explain in detail. I get this car in my shop and it sounds like it has a bag of marbles in the intake plenum.( I now know this has to do with the VIS motors). I changed the flasher relay and the window lift relay from under the steering wheel and a 15amp fuse (F7 or hazard warning switch,hazard warning relay) from under the bonnet. So after all the fuses and relays are replaced all is well with vehicle. Car leaves my shop running perfectly fine. Two days later car wont start,dead battery i thinks. Battery perfect. Put key in ignition and i hear ding ding ding(sound to tell me the key is in the ignition and my door is open). Turn ignition to first position can hear the fuel pump turn on but no dash lights, turn key all the way and nothing. no dash lights no starter click no bells no whistles, nothing except the clock goes out and the interior lamp goes out and I can hear a faint humming noise coming from the fuse box under the dash. And i can hear the relays under the bonnet clicking away. So i check all the fuses and the hazard 15amp is blown under the bonnet and that's it. Please if anyone can help. This is the first time I've worked on a Land Rover Freelander and I'm stumped.
Old Dec 8, 2012 | 12:44 PM
Rovin4life's Avatar
get out a test light. come on dude don't you have access to a wiring diagram. If the starter doesn't start then ask yourself why. Does it have power going to it and everything else. What about the ignition circuit. Does it give you a full twelve volts to the fuse box.
Old Sep 26, 2019 | 02:58 PM
Haakon Nordseth's Avatar
Please help me ! My Freelander 2 had a sudden stop. I thought it was an electronic failure. I checked the contacts on every ECU. But..... IT was the exhaust camshaft broken. Now i have installed amnesti camshaft, but the car has entered hibernating stage. The only thing that happening when trying crank IT, the hazard light on temperature gauge peak, and som few oter Odd thing. What am I gonna do
nooath
Apr 27, 2014 02:53 AM
Rayyag
Feb 16, 2009 09:14 PM
nanook4
Oct 28, 2008 02:38 AM
STACKER
Jan 17, 2007 06:04 PM
nick
Freelander
Mar 14, 2006 04:41 PM
