Sponsored by: CARiD
starting problems
Old Oct 28, 2008 | 02:38 AM
nanook4's Avatar
3rd Gear
Default starting problems
Have this posted in the freelander forum.
My fuel pump does not work when ignition is turned on, I suspect a defective relay in the fuse box. What is the best way to test the relay using a volt meter? And what kind of readings should I see on the volt meter display?
I drove from work to home, about a mile, put the vehicle in park and it just faded out and quite running. And would not restart. This is a 2003 Landrover Freelander (V6) purchased Used. More information, gas tank full, battery 100% charged, starter will crank engine, all fuses okay.
Any suggestions would be helpful.
Thank you,
nanook4
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
STACKER
Freelander
May 14, 2008 08:33 PM
baysiderover
Oct 6, 2006 06:58 PM
hsmatharu
Freelander
Sep 14, 2006 04:56 AM
finetrophywife
Aug 5, 2005 03:40 PM
