Freelander Talk about the Land Rover Freelander within.
Freelander2 jumps standstill to Drive
Old Dec 18, 2022 | 06:00 AM
john.shepherd's Avatar
Default Freelander2 jumps standstill to Drive
Hello all, this my first post. We have a Freelander 2 HSE SD4 Auto 12 plate. In a nutshell, in stop start traffic when you lift off the brake pedal (and are in Drive) the car will roll (if on a slope) and then after about a second jolts forwards. It feels like it is shifting very badly from neutral to first gear. It only does it when it has been driven for a while and after a few stop starts. Holding the brake for more than 5 seconds before lifting off brake (transmission in D) seems to be required to make it jolt. Once it starts jolting (feels like you have been hit by a car from behind!) it will continue to do so. Normal gear changes are not affected.
Its been with a Land Rover main dealer for 3 weeks and they have changed the Haldex clutch (to fix another issue and they thought hopefully this too but alas not).
I know a bit about cars...to me its the transmission shifting to Neutral when it shouldn't or the torque converter doing something silly.
Has anyone any suggestions?
Thank you!
John
Old Nov 19, 2024 | 03:17 PM
DiscoDebbs's Avatar
Hi John, did you ever find out what this issue was? I have exactly the same problem!!! I’ve been ripped of by a garage with this car, already replaced the rear diff and now the front also needs changing and now this!!!
Old Nov 26, 2024 | 04:44 AM
james66lloyd@hotmail.com's Avatar
Have they serviced your gearbox oil and filter as it sounds like old thin or sticky gear oil
Old Nov 26, 2024 | 04:53 AM
DiscoDebbs's Avatar
Hi, yes complete flush of gearbox so all lovely new oil!
vasyaka
Jun 28, 2023 11:00 AM
AdventureMarsh
Defender
Sep 23, 2022 06:19 PM
petrolderek
Feb 3, 2018 12:36 AM
bigbalu
Aug 30, 2013 10:05 PM
elrocha69
Dec 14, 2007 05:42 PM
