Freelander Talk about the Land Rover Freelander within.
Help - What is this?
Old Jun 30, 2012 | 11:25 AM
racer2's Avatar
7th Gear
Default Help - What is this?
I was looking down the side of my 2003 Freelander's engine and pulled this tube out thinking it was the tranny fluid dip stick. It's on the passenger side (US) lower engine. Well as soon as I pulled it out I knew it wasn't. But how do I put it back. Where does it go? I took my phone and took pictures. Took the wheel off to see if I could get a better look. I do not see any hole for this thing. Does anyone know what it is and where it goes? Any help would be greatly appreciated.
Old Jun 30, 2012 | 12:25 PM
You might want to page thru the particular parts of the RAVE for your truck. In many other Rovers, a plastic pipe with a 180 degree end is a vent for something like an axle, transfer case, etc. In your case probably the intermediate reduction drive (IRD).
Old Jun 30, 2012 | 12:28 PM
nahtanoj's Avatar
mine is still attached and i've been meaning to look where it goes. i'll see if i can figure it out and let you know.
Old Jun 30, 2012 | 01:14 PM
racer2's Avatar
7th Gear
Thanks guys. I found where it attaches with a mirror and a flashlight. It's a small rubber tube way back under the engine. Very hard to maneuver back into position. I put a little soap on the tube and pushed it in. it's some sort of vent. The tube wasn't greasy at all after 110K miles so It probably doesn't vent much.
Old Jun 30, 2012 | 01:58 PM
Yes, but it vents above the water line whilst wading....
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
