Freelander Talk about the Land Rover Freelander within.
Problem with my 2002 freelander overheating !
Old Jan 14, 2017 | 09:52 PM
Dconch12's Avatar
Default Problem with my 2002 freelander overheating !
Hi i have an issue with my 2002 freelander , so i recently did a coolant flush im new to landrover mind so i dont have alot of knowledge, so i replace the coolant and replace the coolant reservoir , i filled the resovir and it didnt take much coolant it only took one of coolant it would not take anymore so i turn it on and it didnt go down(the coolant didn't get lower) and this scared dude to the fact that i took out the coolant in the first place so im not sure why its not going lower i read online that there is a bleeder i opened the bleeder and coolant just came out and i closed i drover it around the other day but it would not over heat and just today in stop in go traffic it started to over heat i appreciate your help in advance thanks .
Old Feb 24, 2017 | 01:18 AM
Glyndwr's Avatar
6th Gear
Hi , you don't say which power plant you have fitted , if it is the "K" series petrol engine this is a common problem with them , is your cooling system working well , i.e. good radiator , water pump and head gasket good not blown ?
tyethornton
Jan 29, 2015 10:38 AM
Disco_Fever
Dec 6, 2013 06:16 PM
philiplarson
Jan 5, 2009 03:15 PM
Concrete
Nov 3, 2008 01:51 AM
washington2133
Freelander
Sep 30, 2008 06:24 PM
