Rear window operating incorrectly
I have an '02 Freelander, and the rear window is not operating correctly.
When I pull the lever to open the rear door, the glass drops correctly. However, when you release the lever, the glass returns upward.
This requires the operator to hold the lever depressed while shutting the door in order to get the glass to clear the trim. Sometimes this can be quite a trick.
Does anyone have a suggestion for where to look? I don't want to just start replacing components.
Thx,
Squid
Thx,
Squid
I am new here with the same problem as multiple folks. The rear window(since batteries been off) will not stay up.If I go to put the window up it reaches the top and then beep beep straight back down.I have used the search facility on here but cannot find an answer.
Please help chaps and hello
Mik![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
Mik
