Freelander Talk about the Land Rover Freelander within.
Rear window operating incorrectly
Old Jul 13, 2009 | 12:39 PM
squid's Avatar
4wd High
Default Rear window operating incorrectly
I have an '02 Freelander, and the rear window is not operating correctly.
When I pull the lever to open the rear door, the glass drops correctly. However, when you release the lever, the glass returns upward.
This requires the operator to hold the lever depressed while shutting the door in order to get the glass to clear the trim. Sometimes this can be quite a trick.
Does anyone have a suggestion for where to look? I don't want to just start replacing components.
Thx,
Squid
Old Mar 19, 2012 | 10:40 AM
samharry11's Avatar
3rd Gear
I am new here with the same problem as multiple folks. The rear window(since batteries been off) will not stay up.If I go to put the window up it reaches the top and then beep beep straight back down.I have used the search facility on here but cannot find an answer.
Please help chaps and hello
Mik
Old Mar 20, 2012 | 02:13 PM
samharry11's Avatar
3rd Gear
Default Fixed it
Stripped the door panel off and the wiring loom clips were being trapped by the window dropping so the glass was not able to drop all the way down
One problem down only another two to deal with then I can use the car.
Mik
Old Mar 31, 2012 | 05:14 PM
David Nickols's Avatar
5th Gear
Had the same problem. Had to replace the cable mechanism at considerable expense - even for one from a wreck.
happycamper
May 4, 2010 02:01 PM
ainiguez
Apr 25, 2009 09:49 AM
husker6:33
Jul 17, 2008 03:33 AM
dwc
Mar 23, 2008 03:55 PM
racdisco
May 13, 2007 08:03 AM
