Freelander Talk about the Land Rover Freelander within.
Ticking Noise from engine
Old Jul 14, 2008 | 12:41 PM
louianquin's Avatar
5th Gear
Default Ticking Noise from engine
I recently had my cylinder head removed from my 2001 v6 freelander due to a cylinder 6 misfire, during this work two exhaust valves andtwo inlet valves were removed and replaced. The garage also renewed the head gasket and bolts aswell as the timing belt. The cooling system was bled and subsequently refilled. Since this work has been done i have noticed that my engine makes a tapping noise when and during acceleration, there is also a strong burning smell from the exhaust? I took it back to the garage to point out my concerns. They have suggested that the tapping noise is a hole in the exhaust manifold gasket and the strong smell will wear off and is due to the work that has taken place???? in addition the inlet manifold was replaced 6 months ago. ANY SUGGESTIONS
Humdinger
Oct 18, 2016 05:05 PM
john65b
Oct 10, 2013 05:00 PM
30more
May 28, 2012 05:01 PM
mupmanyu
Mar 7, 2011 05:42 PM
DeepBlueWater
Sep 27, 2007 07:39 PM
