Freelander Talk about the Land Rover Freelander within.
Trans Problems
Old Sep 29, 2013 | 11:44 AM
HeavyFire's Avatar
Exclamation Trans Problems
I need some help here. I have an 02 freelander when it goes in to 4th gear it revs up high then down shifts back into 3rd. it started as an intermittent problem but now it happens on more of a regular basis. Any help would be great. Thanks
Old Oct 3, 2013 | 08:08 AM
rtonder's Avatar
Sounds like a possible solenoid problem. You can get a replacement set on EBay and do the work yourself for a few hundred. But check the tranny fluid level first. Do so by draining it out and measure what you drain. Should be five quarts. If it smells burnt and is brown, replace with new. I use Castrol Transmax import multi vehicle. Amazon has the best price for six quarts. Low fluid level can cause the shifting problem.
Old Oct 26, 2013 | 11:26 AM
HeavyFire's Avatar
Where is the Transmission Fill for it? Ive looked all over. Also do i need a special tool to do it?
Old Nov 24, 2013 | 11:00 AM
rtonder's Avatar
No special tools. The fill is a small plug on the top of the metal pan that on the front of the transmission, just below and to the left of the battery. You may have to push some of the hoses to the side to see it. About one half inch in diameter. Black plastic. You can slip a short section of 5/8 inch heater hose over the nipple, and then insert a small funnel into the other end of the hose to fill without spilling.
The fill check is on the bottom, adjacent and to the drivers side of the drain plug. You have to turn this out while the engine is running. I never use the check plug, but instead use the drain into a clean pan, and once it is done dripping, pour it into a clean container to measure. Should be about five quarts. If not, add to get that amount and refill. If it is brown, smells burned, replace with the Castrol Transmax import multi vehicle fluid. Will shift much better.
Old Nov 24, 2013 | 11:02 AM
rtonder's Avatar
Every so often Amazon has a deal on a 3 gallon package of Transmax for cheap.
abran
Apr 27, 2014 06:59 AM
Frank4
Mar 21, 2014 05:21 AM
mark norris
Jun 4, 2012 08:54 PM
Luckesc4vett
Feb 18, 2009 07:54 PM
The People Family
Aug 6, 2008 10:32 PM
