Freelander Talk about the Land Rover Freelander within.
Will not move in any gear
Old Oct 15, 2011 | 08:06 PM
sson's Avatar
Default Will not move in any gear
I changed my oil today, and put a little too much oil. So I drained it to the right levels, then turned it on. I put it into R and it won't move. I put it into Drive and it won't move. The parking brake is off by the way. Anybody know what's wrong? Should I drain more oil?
Old Oct 15, 2011 | 08:15 PM
1. You did drain engine oil and not red transmission fluid?
Old Oct 15, 2011 | 08:38 PM
sson's Avatar
Hmmm, yea, I think that might be the problem. How much transmission fluid should I put in since I drained the whole thing apparently? Man do I feel stupid right now...
Old Oct 15, 2011 | 08:59 PM
This is not an easy problem to fix. The RAVE has a set of procedures to follow, this is not Dad's F150, where you pour it in thru a funnel, etc. Read all the attached pages, and please download the whole RAVE, you'll find Freelander in there.
Only thing I see out of normal is reference to temp being 35 - 45 degrees, but that must be C, not F.
Now, if you drained the tranny, thinking it was oil drain, did you put motor oil back into engine or tranny?
If engine, check dipstick, and you must be way over filled, crankshaft can strike surface of oil pool.
If you put motor oil into tranny we have a much bigger issue. Would not crank truck until more is known.
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 15, 2011 | 09:05 PM
Here are pages on oil drain, for the three various engines that come in Freelanders.
File Type: pdf
Old Jul 9, 2019 | 03:06 PM
Randall Stoll's Avatar
Default Not moving
The shaft inside the shifter is broken does that connect to the linkage to put it into gear the vehicle is not moving at all thank you
pottzie
Sep 25, 2012 07:39 PM
rzuluaga
Aug 6, 2012 08:45 PM
tyguru
Apr 24, 2012 09:30 AM
calebbo
Dec 15, 2010 09:03 AM
Antmen
May 6, 2010 10:03 PM
