04 Land rover range rover inactive air suspension
Old Jun 29, 2016 | 03:30 AM
Ada2016's Avatar
4wd High
Default 04 Land rover range rover inactive air suspension
Hi everyone, I am a new range rover owner and feel already helpless on US range rover forum. Bought an 04 range rover l322 3 months ago first issue front driver side air was basted put a remanufactured one in. RR still throwing can bus fault ( too much energy needed to maintain the front axles) now showing HDC inactive too. Took the RR to couple of independent shops first one told me I need a right EAS since I changed the left side one . Not logic since the RR will not drop height when left for 3 day in the lot. Since the HDC and abs brake light come on too the second shop told me that the ecu is not getting info from the transmission control module
That can cause the issue. IvLike the RR but thinking about a coil over or switchin back to bmw's moucho problema RR
Old Jul 12, 2016 | 07:44 PM
BritishautoworksSD's Avatar
Any luck with this?
Look for TSB LTB00058. This can be related to a faulty Air suspension pump, air reservoir valve, height sensor or an air leak.
Old Jul 13, 2016 | 12:59 AM
Ada2016's Avatar
4wd High
Originally Posted by BritishautoworksSD
Any luck with this?
Front R EAS was leaking, I changed the Front L EAS couple of months ago so it was time for the R EAS, still dealing with the HDC and EAS inactive message but no more dropping ; I am just getting ready for a trip to the stealership.
Will give you guys feedback afterward
Thanks for your interest I appreciate it
griff black
Jun 23, 2016 05:59 PM
jakethekid
Oct 3, 2014 09:22 AM
griff black
May 1, 2010 07:33 AM
Nato
Jan 19, 2010 12:40 AM
Brad S1
Sep 2, 2008 11:03 PM
