04 Range Coolant Leak-Please Help if you can!
Old Jan 5, 2010 | 02:07 PM
chendricks207's Avatar
4th Gear
Post 04 Range Coolant Leak-Please Help if you can!
Ok, you tell me what you think...I just returned from the dealership(for diff recall) and there is a huge coolant leak coming from the lower hose running to the radiator. It actually apears to be running from the temperature sensor that plugs into that hose from the top. I pulled the temp sensor and replaced the oring and leak got worse. And what I am seeing is that the sensor actually has some loosness when clicked in. My question is should I remove and replace the sensor? Is this a common problem with this model? are there any temporary remedies to this(ie. loctite or some kind of sealant)?
But when I start the truck you can see the coolant runs directly off both sides of sensor where it clicks in to place. Please help, any advise would be greatly appreciated.thanks
Attached Thumbnails 04 Range Coolant Leak-Please Help if you can!-temp-sendor.jpg
Old Jan 5, 2010 | 04:21 PM
handsome rob's Avatar
It must not be in place properly, the new o ring could be causing it feel like it is in but then in reality not set in. Try playing with it again.
Old Jan 6, 2010 | 06:15 AM
Rovin4life's Avatar
its a BMW problem. you can't get that oring. We have already tried. You have to get the entire part.
Trust me we tried to fix ones like that and it dont work. BMW does that. instead of a simple gasket they make it so you have to put an entire part in it.
Old Jan 6, 2010 | 08:10 AM
4th Gear
Thanks for your help Rovin4life, I found this thread last night as well to back up your point...
http://www.bimmerfest.com/forums/sho...d.php?t=385920
do you recommend I buy aftermarket, or from LR or BMW?thx
Old Jan 7, 2010 | 08:25 AM
4th Gear
Smile
Weel, Its Fixed. Thanks to the help of this forum leading me in the right direction. I actually had planned on purchasing the whole sensor w? o-ring included and then I luckily read this thread befor I did...
http://www.bimmerfest.com/forums/sho...2085&highlight=
Could not find this particur brand o-ring but from dimension got it from my neighborhood hardward stor. Before with my old o-ring the sensor would click into place very loosely. Now I needed to push with force to pop the sensor in place. Sealed well! And the car runs great. Thanks for all your help!!!
ZMonet
Jun 24, 2016 04:00 PM
hamad ss
Jan 25, 2015 03:54 PM
calebbo
Oct 12, 2011 09:54 PM
brennan711
Apr 14, 2011 05:57 PM
chendricks207
Jan 11, 2010 03:21 PM
