1998 4.0 no ignition, dash lights.
Old Jun 24, 2012 | 11:23 PM
fire57dan's Avatar
Default 1998 4.0 no ignition, dash lights.
For the last couple of weeks the message center has said that the key battery is low, I replaced it twice and it is still low. A local RR specialist said the circuit in the key is most likely to blame. Yesterday I turned the key and nothing turns on except the SRS light and I can hear the fuel pump. No dash lights besides the SRS. The low range selector lights up and the radio code light blinks. Aside from that nothing. I ran the hawkeye on it and it shows code 1607 MIL circuit. All fuses are good I wonder if the computer went or if the key had something to do with it?
Old Jun 25, 2012 | 05:40 AM
see FAULT CODE P1607 - could be skinned wire between ECU and other modules.
Old Jun 25, 2012 | 11:42 PM
fire57dan's Avatar
Ya i suspect a loose connection or wire. For the time being i disconnected the battery, reconnected it and it started right up as normal. The key works locking and unlocking all the doors as well. Well see if it reappears.
will rocket
Off Topic
Sep 12, 2013 06:23 AM
TexasDiscovery
Aug 6, 2013 12:54 PM
1998DiscoverySE
Jun 27, 2012 01:56 PM
Doral300sc
Feb 6, 2010 03:59 PM
tonyzp007
Jan 26, 2007 11:21 PM
