1999 Range Rover Head light replacement
Old Oct 1, 2008 | 02:13 PM
mgabriel's Avatar
Default 1999 Range Rover Head light replacement
Hi,
Can anyone come up with an explanation of why one of my headlights continues to burn out? I just replaced the same one and not an hour later was already burned out. Just a coincidence, or are there any possibilities?
Thanks,
Michael
Old Oct 1, 2008 | 02:41 PM
bhorwhat's Avatar
Default RE: 1999 Range Rover Head light replacement
did you replace the entire assembly or just the bulb? I know from experience that you can't touch the bulbs with your fingers - the oil from your skin will cause the bulb to get extremely hot and burn out.
Old Oct 1, 2008 | 02:52 PM
mgabriel's Avatar
I only relpaced the bulb, assembly is fine. I didn't touch it and it was wrapped in a static wrap, so couldn't have gotten any oils on it. May have been a mere coinsidence. I have a replacement coming tomorrow and will post only if it burns out the same.
Thanks,
Michael
Old Oct 1, 2008 | 10:36 PM
mlshelton's Avatar
I had this happen repeatedly on a P38 - finally replaced the fitting under the rubber "boot" that the bulb plugs in to - problem went away.
Not a technical answer by any means but something in there appeared to be getting too warm and shorting the bulb out.
bennyb43
Nov 28, 2015 04:01 PM
Waldeny
Jun 2, 2014 07:23 PM
timmy264
Aug 17, 2012 07:39 PM
mgabriel
Dec 11, 2008 11:53 PM
mgabriel
Dec 8, 2008 02:33 AM
