2000 4.6 HSE alarm problem
Old Oct 27, 2009 | 04:38 PM
jfhwyom's Avatar
5th Gear
Default 2000 4.6 HSE alarm problem
I unlocked the rover, the alarm went off. I put the key in the ignition and the alarm is still going off. Then I try to start it and the 'engine disabled' message flashes. I tried disconnecting the battery and reconnecting with key in position II and using the '1515' EKA procedure with no luck (both suggestions from Rangerovers.net). I'm guessing the lock isn't recognizing the key as anytime I touch the car, the alarm goes off. The buttons haven't worked on the key fob for a couple weeks. Any suggestions? Wires I can cut? Any way to bypass the alarm? Thanks.
Old Oct 27, 2009 | 04:42 PM
Jordanmd88's Avatar
http://www.rangerovers.net/repairdet...rm.html#naseka
Scroll down till you see the part about unlocking it once then locking it 5 times ect.. That has worked on One of our Rovers when it did this...
Old Oct 28, 2009 | 10:14 AM
jfhwyom's Avatar
5th Gear
Thanks, I tried that and it didn't work. I ended up getting it towed to my local Range Rover mechanic (love AAA plus). He said it's probably the chip in the lock not recognizing the key (and I only have one) so most likely new chip or lock, new key. I'll post when I know for sure.
dofbft
Aug 15, 2013 11:52 AM
ccasseljr
Mar 29, 2011 05:50 PM
Princess
Jan 30, 2010 10:35 AM
Kennyr996
Jan 5, 2009 03:47 AM
coleyRR
Aug 19, 2008 04:56 PM
