2001 range rover washer pumps
I just purchased a 2001 range rover and Im trying to work on the washer pumps. none of them are working. Im trying to locate the fuse for these pumps. so far all the fuse's I have found are good. (I've checked the ones under the right hand seat and on the fender well. ) are there other fuse blocks i should be aware of? I didnt know if there are any in line fuses i should be aware of. or any hints anyone knows to get these pumps back on line.
Don't see fuses that just control pumps and nothing else. But the pumps all share a common ground, see pix. E181. At least on the RAVE manual before 2002. After 2002 it is C0017.
Both models use the BECM to directly supply 12 volts to washer pumps, so while there is a BECM fuse, it runs a lot of other stuff as well. That common ground might be the common link.
thanks for the advise. Ill check the ground. There are a couple of more problems Im trying to work out on it. I'll just try to fix one at a time. So far I love my Rover.
Lincoln Tarantino
04-01-2012 09:32 PM
rinmud
08-12-2006 07:12 PM
