2002 Range Rover Trailer Light - FUSES?
Old Oct 13, 2011 | 07:31 PM
mictouch's Avatar
4th Gear
Default 2002 Range Rover Trailer Light - FUSES?
I have a 2002 Range Rover 4.6 and I connected an adapter to convert a 4 wire brake setup to a 3 wire. I found the factory harness behind the passenger side tail light and all the wires check out properly. I hooked everything up and all of a sudden I lost power to the trailer plug for the brake lights and the turn signals. The running lights are working perfect. Any Ideas?
Is there a fuse that powers the trailer light harness?
Everything else is working perfect on the car. The tail lights work perfect along with the turn signals and brake lights - it is just the trailer harness that went dead...
Gary
Old Oct 13, 2011 | 08:18 PM
See attached from RAVE tech manual, if you have always wanted your own set it is free to download below. There are multiple fuses and fuse links involved. Each is listed in the text.
File Type: pdf
Old Oct 14, 2011 | 01:42 PM
mictouch's Avatar
4th Gear
Default Keyless Entry - Remotes - Aftermarket?
Thanks so much.. I figured it out. There was water inside my tail lights on my trailer causing it to short. I replaced the tail lights and everything works perfect.
I really appreciate your help...
P.S. is there any remote systems to replace the factory keyless entry? Mine is also wet and rusty.
Gary
gruehle
Jul 27, 2020 09:10 AM
B.Young
Mar 30, 2011 11:11 AM
OxyCoRover
Jan 27, 2008 09:56 AM
The Capstone
May 11, 2006 12:57 AM
