2006 RR HDC, Brake (Amber) & suspension lowered
Old Sep 26, 2016 | 08:27 PM
Hanomag's Avatar
Default 2006 RR HDC, Brake (Amber) & suspension lowered
I have a issue with the 2006 Range Rover HSE that I cannot figure out. On startup I get a ping then HDC, Brake Light (amber), the DCS illuminated, and when I start to move I get suspension lowered. I am at a loss and wonder if anyone out there can put me in the right direction?
Prior to this I would get the occasional HDC fault and the middle and lower lights for the suspension would illuminate. A simple turn off and restart would correct the issue but now nothing will help?
I have a RSC software and I do see a Yaw sensor default?
Old Oct 5, 2016 | 07:20 PM
LR Techniker's Avatar
Have you scanned the systems for fault codes? Could be something simple like faulty tail/brake light bulb, faulty brake light switch, weak battery, etc...
Old Nov 18, 2016 | 11:08 AM
mitche's Avatar
3rd Gear
Default Did you get this sorted?
I have the exact issue, and when I google it or do a search on various forums
it mostly come up to an ABS question. However I do not have the ABS light lit.
I only have the ones lit as shown in picture..
Attached Thumbnails 2006 RR HDC, Brake (Amber) & suspension lowered-1460438.1109.jpg
Old Nov 27, 2016 | 01:20 PM
mitche's Avatar
3rd Gear
Now I have disassembled basicly the whole interior just to find out that there are perfectly looking connections on the YAW sensor, also the measurements are looking good.
Next thing is to remove the SAS (steering angle sensor) and see if thats where the problem is.
One more layer to go berfore I find the YAW sensor...
YAW sensor connector
Searched a long time for this YAW sensor PINOUT.
Old Jan 1, 2017 | 10:34 PM
Greggles's Avatar
My first check would be the battery. Multiple faults often tie to a weak battery. When was the last time you replaced it
Old Jan 2, 2017 | 05:27 AM
mitche's Avatar
3rd Gear
Default Problem solved....
Hi all...
Just wanted to brief you all about my solution.
I did what everybody else did:
- Changed the Brakeswitch
- New battery
- found some faulty wires under the door sill, rewelded these...
- changed brakepad sensors
Same problem still....
Then I ordered a used YAW sensor and swapped it and Voila christmas tree is gone.
I did not neet to resync the new yaw sensor with my car, but I think I was just lucky and you cant count on it.
Well Cheers
Happy new year.
Mike
Aulmeck
Feb 4, 2022 05:18 PM
rhodesrt@gmail.com
May 2, 2016 12:49 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
colin2496
Nov 5, 2009 09:05 PM
