Amber Brake light and HDC Suspension Fault
Old Apr 30, 2016 | 01:44 PM
rhodesrt@gmail.com's Avatar
3rd Gear
Default Amber Brake light and HDC Suspension Fault
All,
I just took my '08 in for new front tie rods and rear brakes at a small shop and when I picked the car up the amber brake light and HDC suspension faults lights came on. And then the car tipping light came on. Is there something they could have done to cause this to happen. I find the timing too hard to think they are unrelated. I did have them replace the rear brake sensors with cheap aftermarket ones, could that be the culprit?
Thanks
Old Apr 30, 2016 | 05:51 PM
DavC's Avatar
Yes should have gone OEM for sensor. Computer hates weird components.
They may have tapped a few other sensors/wires. HDC fault can be triggered by a suspension fault, or low voltage. I am guessing brake shop messed up some wires around brake areas.
Old May 1, 2016 | 06:04 PM
mx468's Avatar
Did you get an alignment? Check your steering angle. My truck got new tires and a alignment but the steering angle calibration was off by 10 degrees.
Old May 1, 2016 | 08:47 PM
BritishautoworksSD's Avatar
I agree with mx468. Sounds like steering angle calibration is slightly off and needs to be recalibrated. Tie rods usually means an alignment needs to be performed.
I've used aftermarket pad sensors many times without an issue, would be surprised if this is the case.
Old May 2, 2016 | 12:49 PM
DavC's Avatar
Since I cut a wear sensor open just yesterday I should amend my statement to agree with the others, it is probably not the sensor.
houm_wa
Jun 15, 2015 11:21 AM
06Range
May 8, 2013 09:01 PM
