2006 RR Sport drivers side window won't work
The window is up but doesn't work go down when the switch is used. No noise either from the motor. The fuse is good and I just replaced the switchpack. I started with the switchpack cause it was the least expensive item to replace and will go from there. All the other windows operate. I also disconnected and re-connected the battery thinking I needed to reset. Any clues?
Thanks, Steve
Thanks, Steve
twoxred
10-04-2021 07:07 AM
Sattman69
07-16-2015 06:38 AM
