2006 RR Sport drivers side window won't work
Old Jan 16, 2010 | 12:31 PM
scwkof's Avatar
Default 2006 RR Sport drivers side window won't work
The window is up but doesn't work go down when the switch is used. No noise either from the motor. The fuse is good and I just replaced the switchpack. I started with the switchpack cause it was the least expensive item to replace and will go from there. All the other windows operate. I also disconnected and re-connected the battery thinking I needed to reset. Any clues?
Thanks, Steve
Old Jan 16, 2010 | 03:44 PM
Rovin4life's Avatar
why throw parts at a problem when you could be diagnosing the problem. You know checking for power and ground at the motor and the like.
if you you don't know what you are doing and don't want to buy a subscription for the information then take it to somebody who will.
Old Jan 16, 2010 | 10:28 PM
wilson96rr's Avatar
I would remove the door panel and check the connections in the door. You should be able to check for voltage there also at the motor. Not sure if there is a relay that would supply power to the window motor.
twoxred
Oct 4, 2021 07:07 AM
Sattman69
Jul 16, 2015 06:38 AM
jbunner
Jun 5, 2012 08:48 AM
lionel
Oct 15, 2007 10:53 AM
bruxros
Aug 5, 2005 01:54 PM
