2006 RR Sport Sway Bar Question
Old Jun 5, 2009 | 02:01 PM
Mountain_Rover's Avatar
7th Gear
Default 2006 RR Sport Sway Bar Question
Hey guys,
I'm considering purchasing a 2006 RR Sport and when I called the dealership to inquire about the maintenance history they said the sway bar bushings were replaced (@ 37500 miles). FYI, I noticed that this particular RR has the towing package installed. I'm not a mechanic so could you tell me why the bushings would have to be replaced so soon?
Old Jun 5, 2009 | 02:25 PM
ldivine's Avatar
If the previous owner towed quite a bit or towed a heavy load it definitely could wear out the bushings much faster then you would typically expect. Nothing to be overly concerned about.
Old Jun 5, 2009 | 02:59 PM
7th Gear
thanks ldivine,
that makes sense,
should I be concerned with premature engine or transmission wear that might be associated frequent towing or towing heavy loads?
Old Jun 5, 2009 | 10:45 PM
ldivine's Avatar
Engine and transmission wear shouldn't be noticeable unless the previous owner was towing near the max recommended weight. Rovers are great for hauling so I wouldn't worry unless you notice engine or transmission trouble on a test drive.
Let us know if you pick up the Sport after all, we always welcome new Rover enthusiasts... regards!
deer4011
Jan 12, 2021 07:10 AM
ESPN
May 12, 2014 05:27 PM
toofaroffroad
Aug 29, 2013 12:25 PM
Speed racer
Nov 11, 2009 09:44 AM
RoverRover1
Jun 25, 2009 03:10 PM
