3 buttons above driver door
Old Jul 14, 2005 | 01:28 PM
battsup's Avatar
4th Gear
Default 3 buttons above driver door
I have a 97 range rover 4.0L and above my driver door there is like this pod with three buttons on it, looks like a programmable garage door opener or something, does any1 kno how to set it up? thanks in advance.
Old Jul 14, 2005 | 10:46 PM
37chambers's Avatar
Default RE: 3 buttons above driver door
Its a garage door opener. Owner manual tells how to program it.
Old Jul 15, 2005 | 03:52 AM
battsup's Avatar
4th Gear
The problem is that i dont have an owners manual. is there sumwhere where i can view an online owners manual or sumthin? or can sum1 tell me how to program it? thanks
Old Jul 15, 2005 | 03:02 PM
mikemeyer0's Avatar
ok this is pretty funny, after reading this post i went and tried it. I took the garage door opener for the overhead console, above the rear view mirror, and moved it to the area by my head above the seat belt, then took the blank from there and it fit in the place the garage opener was, so anyway the point is someone prolly moved it there. Is there like a plastic blank on the overhead console above the rear view mirror right under the light? it should go there, also when car is running and you push buttons does the red light, light up?
here is how to program your home link
1. Hold the outer two buttons of the home link until the light blinks slowly, release.
2. Hold the button you want to program (on homelink)
3. While holding the homelink button down press and hold the door opener till the light on the home link blinks fast.
4. Repeat 3 on another home link button for multiple doors.
Old Jul 15, 2005 | 10:29 PM
teamyonex's Avatar
The HomeLink on a 1997 might not work on newer garage doors with rolling codes. The HomeLink on my '97 Disco did not. To get it to work you would need to hardwire the garage door opener differntly. HomeLink does work on Land Rovers '98 and newer, however. See http://www.homelink.com/home/global.taf for full details. Good luck
joshp01
Dec 5, 2021 07:50 PM
Princess
Sep 15, 2009 08:02 PM
mummra
Apr 26, 2008 02:11 PM
Crusoe
Jul 1, 2005 11:10 PM
