Acceptable oil pressure values
Old Jan 17, 2016 | 02:22 PM
Roveroh's Avatar
Default Acceptable oil pressure values
I have a 2004 RR. Had a low oil pressure warning last night, but no oil light.
I tested oil pressure values and have them below:
idle 10psi
1000 rpm 20psi
2000 rpm 50psi
Are these too low? If so, am I looking at a new oil pump? Also, is there a write-up on a oil pump R and R?
Old Jan 17, 2016 | 03:45 PM
number9's Avatar
Originally Posted by Roveroh
Are these too low?
Did you look in your Workshop Manual for the specs? If you don't have one, manuals are available and downloadable sans cost. If you have one already use it.
Start and run engine until normal operating
temperature is reached.
Specs look like you're good to go if checked per the manual.
File Type: pdf
wiscodread
Dec 17, 2023 11:06 AM
carnut
40
Feb 19, 2011 06:50 PM
Chrisinhouston
Apr 9, 2010 04:58 PM
tsuami1
Aug 10, 2009 08:48 PM
mrcrptguy
Jun 7, 2009 06:01 AM
