AIRBAG FAULT ETC
Old Apr 11, 2008 | 08:13 AM
mom2bekah's Avatar
4wd High
Default AIRBAG FAULT ETC
OK, Here we go again. Car has been doing just fine and just passed its annual safety inspection, so I cannot really complain. Last week, I noticed that the clock light was out and the same day the interior cab light went out. Today, started the car to find it has a srs/airbag fault. I looked in the manual and obviously need to check the fuses and bulbs. I have no idea how to get to the clock bulb.
Is there a relay that operates the srs? Is there something I should check before taking it in?
I have a 2000 rr 4.0, 129k miles, yellow top deep cycle Optima battery put in last year.
Any suggestions are VERY welcome.
PS Airbag fault should not result in airbag deploying while driving, right? I just want to make sure.
Old Apr 11, 2008 | 12:19 PM
mom2bekah's Avatar
4wd High
Default RE: AIRBAG FAULT ETC
I checked all the fuses and relays and nothing looks fried. I checked all the connections under both seats and used compressed air on all connections. I vaccuumed and looked for chewed or pinched wires and found nothing. The fault still shows. When car is started, SRS light goes off for a second, and then comes back on with the airbag fault dispalyed in message center. I checked the bulb in the interior cab and it looked ok, even tried to switch it out with a new one, and no luck. If I hold the button down (center light) message center says and beeps interior off/on, but no light??? Side lights are working fine ??? Still have no idea how to change clock bulb, and am really wondering if these troubles are all connected. Please!! if anyone has any ideas or suggestions they are welcome
Old Apr 12, 2008 | 11:14 PM
roverguy7's Avatar
most likely not connected. good chance you need a new lamp for the overhead light, the board inside goes bad pretty often. the clock can only be fixed by removing the whole center dash piece, inc. both side console trims, the ip surround and the drivers knee bolster. as for the srs light, most likely causes are the seat air bag connectors or the clockspring. need to pull codes to find out, and clear codes, not self clearing. if it is the seat bags, add di-electric grease to the yellow connectors under the seats. should fix that.
[/align]
Old Apr 13, 2008 | 11:52 AM
wease206's Avatar
my has the same problem too .
i change the lights on dash
after that light work but i saw srs light light up
can you plase tell how to removed that light
do you have any picture to post or show how it can be done
or email me if you went
thanks
Old Apr 13, 2008 | 02:09 PM
roverguy7's Avatar
if you mean remove the srs light, no, its a led intraglal to the i/p, and dont, system would not opperate even if you could.
[/align]
achapman
Jun 25, 2013 03:40 PM
06Range
May 8, 2013 09:01 PM
faheemf1
21
Feb 29, 2012 08:41 PM
TheBelly
Nov 1, 2010 08:34 PM
