A/c works when it wants to
Old Aug 4, 2012 | 03:21 AM
PoliticalVomit's Avatar
Default A/c works when it wants to
Hello I just came into a problem with my range rover the a/c will work fine I turn the car off go into a store come out and the temp. Says 50 deg. When it's really 100 deg. Outside and the a/c never gets cold any advise would help on diagnosing this with out paying an arm and a leg. Thanx
Old Aug 4, 2012 | 06:31 AM
Year ? And if you start from home and drive for an hour or two, AC works fines and is cold, as long as you don't stop for a few minutes?
Some later Rovers have a cab temperature sensor inside the dash, that could get fuzzed up or be bad, and that may skew operation. Certain models have a double sunlight sensor to offset for changes on one side or the other of th truck. If one side is "bad" it uses the other for both sides, and if both out it uses "0".
Old Aug 5, 2012 | 06:05 AM
Default Year
It is a 2000 LR RR and some times it gets cooler after driving for a while but a lot of the time it stays hot thanx about the sensors info tho I will check into that
Old Aug 5, 2012 | 07:03 AM
see attached page from shop manual, you are welcome to download the whole RAVE for free at links in my signature.
File Type: pdf
Old Aug 7, 2012 | 08:28 PM
LRScott's Avatar
I've tried to run my a/c compressor near the end of winter to make sure it would work for summer, and it would not kick on. I could not figure it out at the time, but once it became warm outside, the RR decided to turn it on. Your outside temp sensor is probably causing the issue. You can override the automatic system by pushing the temp controls on both sides to their lowest setting "LO", and by selecting re-circ. I've noticed that even in cold weather, the a/c compressor will kick in when re-circ is selected to keep the windows from fogging.
jco
Jul 2, 2008 12:50 PM
xstreetz
Sep 21, 2007 12:15 PM
elguappo999
Nov 16, 2006 04:48 PM
ebone
May 21, 2006 03:02 PM
wkujesus2
Apr 19, 2006 12:15 AM
