check engine light --- '88 Range Rover Classic
Old May 17, 2006 | 04:18 PM
Default RE: check engine light --- '88 Range Rover Classic
ORIGINAL: Peter Varga
We tested the oil pressure sender. When the engine is on, it
grounds the tester. When the engine is off, the sender is open.
I think the mechanic is satisfied that it has enough oil pressure
to motivate the sender change of state. And it does have
fresh oil in it. We'll look into the plugged pump intake however.
Is your mechanic a experienced Rover mechanic? If you are wanting to get to the bottom of your problem, this is one thing you need to check. It doesn't take much to activate the sender, that still doesn't mean the engine is getting enough oil pressure. Rovers are know for oil pressure issue, especially older one with a lot of build up. It is sure easier then pulling the pan for a visual inspection of the mains and pick up tube.
Just a thought,
Mike
Old May 17, 2006 | 10:51 PM
Peter Varga's Avatar
He is NOt a experienced Rover Mechanic. Just a shirt-sleeve tinkerer
trained in military before they had a "throttle-body." And you know
how long that was ago. But...we think it is a wiring issue and not a
pump issue. Just a gut feeling. But thanks for asking. Pete
Jono2003
Nov 24, 2014 11:38 AM
FlyingZebra34
Feb 22, 2014 05:39 PM
umoms
19
Jan 20, 2012 06:55 AM
Bruizza
Nov 8, 2011 03:43 PM
CamRover07
Dec 4, 2007 03:20 PM
