Coolant leak into passenger compartment- front
Old Apr 5, 2010 | 08:20 PM
kdsexton's Avatar
3rd Gear
Default Coolant leak into passenger compartment- front
Anyone ever had this problem? Is it something easily corrected? Looking for any/all suggestions.
Old Apr 5, 2010 | 08:55 PM
wilson96rr's Avatar
Pretty common problem. It is most likely the o-rings on the heater core. Takes quite a while to get to it, but the good news is that the o-rings are really cheap.
Old Apr 5, 2010 | 09:42 PM
krazzz's Avatar
It is usually due to faulty O-rings on the heater core.
Old Apr 8, 2010 | 05:46 AM
EdwardRS's Avatar
5th Gear
As per my opinion it avoid this problem simply change your coolant every 40,000 miles.
Old Apr 8, 2010 | 11:51 AM
kdsexton's Avatar
3rd Gear
Default kdsexton
Thanks to all who replied. While continuing to search the web for advise on fixing my HEVAC problems I found this great site with details and photos on how to replace the leaking O-ring seals and to replace faulty blend motors: http://www.rangerovers.net/repairdet...lendmotor.html. I haven't started to dig into the job, but will soon. I know from my previous under-the-dash work that some things said to be simple to do can be very frustrating the first time you do it.
Old Apr 9, 2010 | 06:24 AM
Rovin4life's Avatar
actually to replace the coolant orings you take out the radio and hvac module and the two sides and the the lower instrument cover on the passenger side. take a long screwdriver number two bit about two feet long and put it thru a spot just underneath the radio housing to fit into the screw. you can feel the screw head and guide the screwdriver into it. what ever you do, don't back out the screw all the way. just enough to release the backing plate.
ZMonet
Jun 24, 2016 04:00 PM
sadain
May 3, 2012 09:40 PM
Granite Disco
Jan 23, 2009 02:18 PM
dbs600
Apr 16, 2007 01:18 PM
