Cruise control not working
Old Jan 13, 2010 | 03:46 PM
fire57dan's Avatar
Default Cruise control not working
When I press the master switch for the cruise control and then press the set button I hear a slow clicking of a relay not switching over from under the dash. When I turn the switch off the clicking stops. Is there a relay for the cruise control somewhere? I looked in the repair manual and its not very complete on the subject. Thanks
Old Jan 13, 2010 | 04:05 PM
Mrmerlin's Avatar
first thing to do is open the hood and then go the DS hood hinge look for the CC bellows and follow the vacuum hoses they are probably in need of replacement a simple fix
Old Jan 14, 2010 | 01:39 AM
LRScott's Avatar
Make sure you ask for a "vacuum" hose at the auto parts store. Ask for at least 3ft, I asked for 6 feet. Just cut them to the appropriate length and then connect them.
Old Jan 14, 2010 | 05:38 AM
wilson96rr's Avatar
If it is not the vacuum lines, there is an easy to follow troubleshooting guide on the Rave CD. And yes, there is a relay. It is called the cruise inverter. I am not sure what it does but it looks like a tall red relay. It is under the dash on the driver's side, to the left of the steering column.
Old Jan 16, 2010 | 06:27 PM
fire57dan's Avatar
I checked the vacum lines and they are cracked almost all the way though. I will replace them next time I go to town. The cables are ajusted properly though. I must have missed the troubleshooting guide, I'll take another look at that as well.
Carlton1
Jul 25, 2012 07:51 AM
csn4646
Aug 28, 2009 09:16 PM
2K Disco II
Aug 11, 2008 10:42 AM
cosmiccharlie79
Jun 16, 2008 09:13 AM
bklahl
Aug 29, 2007 11:20 AM
