Fuel Latch Door Clip and more...
Old Oct 20, 2009 | 12:36 AM
agentbuilder's Avatar
Default Fuel Latch Door Clip and more...
98 Range Rover SE here looking for the fuel latch door clip on the actual door. mine is broke. anyone know a good place to find one. Also need a batter cover, hood struts, and back door struts. and the starage shelf that goes in the storage area, the part on top. our color is tan
Old Oct 20, 2009 | 01:00 AM
LRScott's Avatar
battery cover: http://www.roverparts.com/Parts/ERR3026G.cfm or ebay if you want to pay less.
Fuel door parts: http://www.roverparts.com/Nxt/search...Rover+4.0+(P38)
I think the struts can be swapped out with generic ones from an auto parts store, if not: http://www.roverparts.com/Parts/BHE780012.cfm
Can't find a cargo cover, try ebay.
Old Oct 20, 2009 | 02:33 AM
Default thanks
Thanks for your help
Old Oct 20, 2009 | 07:18 AM
krazzz's Avatar
You should be able to find all of that stuff on ebay for less than you would pay anywhere else.
Old Oct 20, 2009 | 03:58 PM
Default Ok, I am sad
I need to buy a BCM Body Control Module. This sucks
Old Oct 20, 2009 | 04:20 PM
LRScott's Avatar
... ouch
Ebay is probably your best source on this, although it will take awhile. Most of the listings require you to send your old one, they either repair it, or reprogram a used working unit with the data that was on yours and then send you the used unit. Its a risk sending your becm like that, but the feedback looks good and is over a thousand if I remember correctly. Safest and most efficient would be through he dealer, but be prepared to spend A LOT!
Old Oct 20, 2009 | 05:31 PM
Default Yep
We called the Dealer, a little over $1500. Shoot me dead.
Old Oct 20, 2009 | 09:18 PM
LRScott's Avatar
you can get a becm for under 600 on ebay, and like I said most of them will take your old one and reprogram it so all you have to do is plug it in.
Old Oct 23, 2009 | 09:36 PM
D.Opity's Avatar
6th Gear
hi, im after a safari door for a landie, with the hinges etc in good condition, has anyone got one lying around that they want to get rid off? cheers fellas
Sykman
Nov 4, 2018 05:33 AM
Torancis_LR
Jan 2, 2018 06:12 PM
archaeology_student
Feb 11, 2015 09:49 PM
expedio2005
Dec 7, 2012 11:50 AM
Disconoobie
Nov 10, 2007 08:49 PM
