HELP Locked out 2001 P38
Old Apr 8, 2014 | 07:29 PM
georgep's Avatar
Default HELP Locked out 2001 P38
Key is IN CAR doors locked and no 2nd key.
1. Brake glass and eat the cost
2. Call someone with a slim jim
3. Give up and just WALK AWAY
Story:
Car was super locking then unlocking after 20 min. Waited till I could open the door and bonnet. Removed the driver side (left) door control module so that it could not supper lock again, WRONG, Started the car to drive to dealer got out to close the bonnet, door closed since my big butt bumped into it getting around the car. Engine running, Bonnet open and the door locks tripped AS SOON as the door shut. No problem I left the door lock in the open position on the drivers door, BUT it must have slipped down and now can not get back in car. Pulled the fuse to shut off the engine then disconnected the battery. So car is off now and it is 31, #2 or #3 time
Old Apr 8, 2014 | 11:44 PM
tuercas viejas's Avatar
There is away to get into it but for security reasons I cannot openly describe it on this forums.
If you PM me I will give you instructions, and I hope you can still open the hood.
Otherwise you will need a battery some wire piercing fitting and a power probe.
T/V
Old Apr 15, 2014 | 09:16 PM
Fivespddisco's Avatar
Story:
Pop out the little window in the shape of a triangle on the rear door
Old Apr 15, 2014 | 09:39 PM
georgep's Avatar
Ate one and used one, a SLIM JIM, door open now to fix the problem
Old Jan 2, 2022 | 04:56 PM
Sting9876's Avatar
Default Front Doors unlock but won't open
T/V
Hello, while reading the Forums I seen your post. I have 96 RR 4.0 SE that was working fine before Christmas. Then all my windows stopped working. A few days later the front passenget door would'nt unlock or open. So I drove it into the garage to escape Michigan weather to figure out the problem. My son drives the p38 while on college break. Well he said the lock started acting qerky a d he got it to work while out with friends. Fast forward to inside the garage. Since my son said it done this before and he could dix the problem. When I returned home he said dad the driver's door locker a d won't open. The doors unlock a d relocks when I press the remote or use the key. The rear doors open but front doors won't even open from inside the car. I disconnected the battery hoping to reset everything, no luck. I did manage to immobilize the though. I think if I can get the driver's door open I can take off the panel and disable the locking mechanizm. I don't know the EKA Code. Any help would be greatly aporeciated.
Jesse
Old Jan 11, 2022 | 02:13 PM
Harvlr's Avatar
Jesse you should post in the P38 section of this forum. This section is for modifications. Could your front doors be Superlocked? I’m assuming they aren’t just frozen shut.
Old Jan 11, 2022 | 02:14 PM
Harvlr's Avatar
Sorry, not for modifications, but you still should post under P38.
discovery2001
Dec 16, 2020 08:04 PM
morzy41
May 25, 2010 07:18 PM
clout98 disco
Aug 7, 2008 04:03 PM
LockedOut
Jan 14, 2008 12:44 AM
