HELP w/ 94 Classic
Old Mar 3, 2008 | 01:32 PM
BradLuchtman's Avatar
Default HELP w/ 94 Classic
I have a 1994 RR County, I removed all of my carpet and Rhino lined the floors. After doing that I heard a loud noise from the rear, not that they are related at all but when I took out the sound reducing material I thought the noise could have been there before. I ignored the noise andtook the truck off-roading this weekend and blew a hole in my rear diff from the inside out.
So my question is, anybody know of a stronger than stock replacement the is a somewhat easy install? Possabily install a locker or L.S.D. that is cheaper that the ARB ait locker for $800? I belive that the spider gears are not strong enough to weld so that is not an option.
Thanks for any advice in advance.
Old Mar 3, 2008 | 06:13 PM
Default RE: HELP w/ 94 Classic
Did you damage your axle housing?
If not, I would suggest a True Trac diff, very strong design, good traction, they don't fail or require H.D. axles an cheaper then an ARB.
Old Mar 3, 2008 | 10:31 PM
Thanks for the advice, I did damage my axle housing. What ever was making the noise in the rear did not want to stay in the housing and shot out and put a 1/2 in hole in the back of the pumpkin. I do have a complete parts truck that I can take the whole rear end out of but
I wanted to make the diff stronger. I will upload some pics of my truck soon.
Thanks again.
Old Mar 5, 2008 | 11:48 AM
I have been reading up on the rear end of the Classic and I found out the the 94-95 has a different rear than the 1987-1993. Does anybody know if the housing from a 91 will fit into a 94?
Thanks again for any help.
dinandan
Mar 20, 2008 08:22 AM
Classic89
Dec 30, 2007 07:59 AM
Classic89
Aug 23, 2007 04:06 AM
baby0411
Jan 30, 2007 10:42 AM
Ash A
Nov 15, 2005 01:38 AM
