Inside Leak
Old Dec 18, 2008 | 03:58 PM
twenspirited's Avatar
5th Gear
Default Inside Leak
Need some help,
I have a orange likeliquid leaking down in the passenger area - down under left areaagainst the console. I just notice this happening 4 days ago. I thought it was airfresher the detailing shop sprayed. However, when I wipe it from the carpet it appeared again 2 days later. Its not much but it is noticable. 99 RR HSE
Any ideas?
Old Dec 18, 2008 | 09:35 PM
ldivine's Avatar
Default RE: Inside Leak
Sorry I read your post a couple times and wasn't clear... is the leak in the rear seating area? By the A/C vents or elsewhere. When you feel the carpet is it damp, slimy, does the liquid smell or leave residue on your fingers? Orange isn't a good color for a leak but it would be strange to have orange leaking in the rear seating area.
Sorry with some more info might be able to help.
Regards
Old Dec 18, 2008 | 10:31 PM
skyguy's Avatar
Most likely your Heater O rings. If not that then it's the heater core. The orange fluid is your antifreeze fluid. search post for leaking O Rings.
Old Dec 22, 2008 | 02:26 PM
5th Gear
Thanks for the response. The lead is in the front passenger area on down under the dash left side.
It doesn't have a smell but I do smell antifreeze when the heat is on (not sure if that has anything to do with it.) Nonetheless, I'll check the site for leaking O rings.
Thanks !
Old Dec 22, 2008 | 10:47 PM
skyguy's Avatar
been there. it was the O Rings on mine
Old Dec 23, 2008 | 06:16 AM
rinmud's Avatar
o rings, cores never die, dont let the tech tell you its 6 hours either becuase all you need is a long screw driver and remove the a/c face plate and the radio and 30 minutes later wella scott
hhalimi
Dec 13, 2025 08:13 PM
rgrizzard
Mar 6, 2008 10:16 AM
disco12
Off Topic
Feb 2, 2006 02:06 PM
RobFrey1
May 28, 2005 02:24 AM
