"Key still in" beeper - how to disconnect?
Old Sep 24, 2014 | 03:55 PM
kevinocall's Avatar
Default "Key still in" beeper - how to disconnect?
Anyone?
It's a '99 RR P38, every time I shut the engine down and open the door, the dash says "key still in ignition" or something. And an annoying loud beep that never stops. How can I disconnect the beeper? Thanks. Kevin in Minneapolis.
Old Sep 25, 2014 | 08:09 AM
drowssap's Avatar
your problem could be the center of the ignition is not popping out completely when you remove the key.
At least that is what my issue was on my 99 RR, i found that after removing the key if i poked the center on the switch with my finger, it would pop all the way out shut off the warning light.
a couple squirts of silicone solved the problem.
try poking at the center of the ignition switch or removing the key slowly with pressure to see if it shut the warning light off.
Old Sep 25, 2014 | 08:11 AM
slabrat's Avatar
At least that is what my issue was on my 99 RR, i found that after removing the hey if i poked the center on the switch with my finger, it would pop all the way out shut off the warning light.
try poking at the center of the ignition switch or removing the key slowly with pressure shut the warning light off.
I used powdered Graphite . Made everything in the ignition switch run smoother
Old Sep 25, 2014 | 08:50 AM
jafir's Avatar
You can re-configure the BeCM of the P38 to not enable the key in warning.
http://www.nanocom-diagnostics.com/d...CU%20Guide.pdf
Old Sep 25, 2014 | 09:50 AM
kevinocall's Avatar
Default I'll try the suggestions - thanks!
Old Sep 26, 2014 | 09:52 AM
kevinocall's Avatar
Default "Key in" beeper mystery solved ...
Thanks for all the tips.
Sure enough, when key is removed, I can push / release the lock with my fingertip and it comes all the way out. Thanks all, KO>
Old Sep 26, 2014 | 12:02 PM
drowssap's Avatar
may all your repair be as easy
jycsalas
May 23, 2019 03:02 PM
17outs
Apr 9, 2010 11:32 AM
josemex
Dec 20, 2009 08:38 PM
PMKColorado
Defender
Oct 12, 2008 10:49 PM
chadbormann
Aug 1, 2007 05:51 PM
