leaking transmission fluid
Old Nov 29, 2009 | 09:54 PM
nelbra's Avatar
Mine didn't start leaking till after I bought it. About a month or two later, after I got the brakes done, I went out the next morning and practically had a puddle of oil and power steering fluid . I have been parking in my garage on a box for months. I am getting the oil pump gasket replaced tomorrow and a new gear box that I bought from Meridian in San Diego.
Old Nov 29, 2009 | 11:08 PM
LRScott's Avatar
Scott, Isn't there a dipstick? Mine has one. Did LR eliminate them at some point? Just curious.
There are on the gems management system, but on bosch they decided to get rid of it for some reason...Using the fill plug method has its advantages, it is more accurate and prevents overfilling. However, its not as easy to make a "quick" check.
Old Nov 30, 2009 | 05:25 AM
wilson96rr's Avatar
As far as power steering leaks and groaning...I have had great luck with Lucas power steering additive. I am not a big fan of snake oil normally, but in this case it stopped the leak and the groaning noise.
Old Nov 30, 2009 | 08:16 AM
krazzz's Avatar
I second that. The stuff works great. I will be adding it to my Volvo this week. (its already in my Rover)
Old Dec 2, 2009 | 02:49 PM
nelbra's Avatar
I just got a new gearbox in my 92 RR Classic LSE. Do you think it would be worth it to put the Lucas in there? I have a bottle in the back of the RR.
Old Dec 2, 2009 | 06:53 PM
wilson96rr's Avatar
I would say just to put in whatever Land Rover says to use. I think the Lucas stuff is more for things that are basically worn out. I have had great luck with it in my power steering pump however I know that the pump has a lot of wear on it. It seems to have a higher viscosity than the standard fluid, thus creating more pressure and reducing the tendency to leak.
Old Dec 2, 2009 | 07:23 PM
Baylink's Avatar
Disco 2's do not have a dipstick: you fill and check from a rear-facing plug on the back of the pan. Which, yes, is a pain in the ***.
Old Mar 23, 2016 | 01:56 PM
tommyg99Rover's Avatar
Default Transmission leaking
Is it normally the seal that is leaking?
rally1
Feb 22, 2022 06:22 AM
Athana
Jun 8, 2019 10:23 AM
Swede
Aug 29, 2012 09:29 AM
mydisco03
Mar 3, 2012 01:09 PM
sfxgamer
Nov 1, 2007 01:42 PM
