lefter sound
Old Apr 12, 2007 | 11:29 PM
wease206's Avatar
Default RE: lefter sound
by the way I love all rover and this is the only SUV i would buy
Old Apr 13, 2007 | 06:05 PM
greg409's Avatar
If you don't know of a good shop in your area, I would ask around (auto parts store, gas station, friends, etc.)
with vapor out of oil filler tube(especially after warmup), you may have more issues than a sticking lifter.
depending on how much vapor
If you take it in, ask questions and expect answers that you can deal with.
If it were me I'd take it in even if it were to the rover dealer.
I doubt they're the cheapest, but they had better be able to give you a decent diagnosis. (in writing)
let us know- thanx
Old Apr 19, 2007 | 02:39 AM
wease206's Avatar
okay
Old Apr 19, 2007 | 11:29 AM
Why don't you send me your tele number and I'll call you about this.
Mike
mikeljacobs@comcast.net
Old Apr 19, 2007 | 03:07 PM
geoman's Avatar
The "bottom line" here is that--if-- after using the flushing agents described , the lifter noise does not go away, then you have a rocker arm and/or rocker shaft problem, which is not uncommon on these engines (especially if they were not serviced properly). If the noise persists, have a shop connect a mechanical oil pressure gage (on the front timing cover --after removing the oil pressure sending unit) and verify the pressure is up to spec. If so -- then you are probably looking at valve-train repairs. Ifa valve(s) is sticking in the cylinder head (another known problem area) it will cause a engine mis-fire and usually illuminate the Check Engine Light (CEL)when the computer stores a number of sequential misfires.
regards,
Geoman
www.eurotekapg.com
Old Apr 27, 2007 | 12:20 PM
wease206's Avatar
i have just found the problem the head gasket need to be replace and rocker shaft problem i have pay LRDealership to locate all the problem with reg they charge me $55.00 and they advised me that the cost of it is part for head gasket is online price $290.00 dealer price $500.00 rocker shaft $514.00 labor is $1500.00 also Valve grind $300.00 (possibility). and they that will fix everything.
they have also include these need to be fix also
Oil pan gasket $206.98
Rear diff pinion seal $310.00
T-case output shaft seal $325.00
Heater core o-rings $525.00
but you know i doing it my self now that i have found the problem
REMEMBER, it's only a machine
Old Apr 28, 2007 | 01:48 AM
94LWB's Avatar
7th Gear
I had a similar issue with an older RR a few years ago and I used two bottles of Lucas oil treatment with each oil change in addition to the de-sludge and that seemed to help as well.
Good Luck
[align=left] [/align]
Old Apr 30, 2007 | 03:31 AM
wease206's Avatar
hi mike thanks for talking to me today it help alots and it made my better.
again THANKS
Old May 5, 2007 | 11:58 PM
wease206's Avatar
i have just fix it myself easy no pain at all sound better!!!!
mvjimenez
Jun 12, 2010 10:25 AM
jvanbelkum
Oct 22, 2007 02:20 PM
philipm7
Aug 27, 2005 10:12 PM
lenra
Dec 9, 2004 06:09 AM
matthew.shore
Dec 2, 2004 04:10 PM
