Low Oil Pressure Light
Old 04-26-2007, 01:43 AM
houstonhelix's Avatar
8th Gear
Default Low Oil Pressure Light
I brought my 90RR back to life after sitting out in driveway for almost three years. A couple of shots of starting fluid did it. All the dash lights remained on as it idled. I added a can of MarvelMysteryOil in the crankcase, and a can of B12 Chemtool to the1/4 full gas tank. I let it idle for20 more minutes disconnected and reconnected the battery. All the dash lights are good off now, but the Low Oil Pressure light remains on.
Can anyone provide some advice on how to diagnose the problem? Bad oil pump? Is it safe to continue to let the engine idle with the light on that perhapsrecirculatingoil additive would resolve the problem?
Thanks!
RON
in Houston
Old 04-26-2007, 10:52 AM
Default RE: Low Oil Pressure Light
Do an crank case flush ASAP, and get all the sludge build up out of your engine and then see if the light stays on.
If you want help with this, get back to me.
Mike
rewi9d
04-12-2012 06:12 PM
eaglewing
04-16-2011 11:06 AM
tito5590805
10-04-2010 09:11 AM
DooDer
01-12-2010 10:46 PM
Cessna310Guy
12-07-2008 02:38 PM
Quick Reply: Low Oil Pressure Light
