minor problems
Old Jun 28, 2007 | 08:18 AM
rodrick smith's Avatar
Default minor problems
I have a list of minor problems. that i want to fix at some point maybe even today. 1999 hse
1. the 2 little lights in my tailgate down work, i took it apart and untape it and recut the wires and re did them but they still don't work. but there is a little light in the tailgate (3 lights total) and it is before the other two and it works.
2. well this i can change my tire for the spare i guess but my back tire leaks air it take about a month about it leaks i can't find out where i had two different places look they couldn't find anything nail or nothing. i think the valve maybe not even sure i have looked for 6 months or so.
3. i have springs instead of air shocks and my air shock light are all on the dealership told me to take out the lights (real good fix but maybe that is what i will do, how hard is it to remore the dash to pull out those lights or light.
4. my defrost only seems to work on the passenger side, this i haven't looked into but now that i am writing this i will do it today if i have time, this fix i have till winter :-)
5. well my windshield spray jet i just need to replace.
6 oil leak but i will let the dealer mess with that.
i only let the dealer do big stuff all the small stuff i do myself
Old Sep 3, 2007 | 03:37 PM
Bleacho's Avatar
Default RE: minor problems
regarding your leaking tyre,
- get a can ofthe tyre leak sealant stuff & sprayin through the valve,that will find & seal the leak easily.
cost approx£7,
dash & air shock light is okay-ish to remove, be careful to line up everything when re-installing as a misalignment that gets tightened up can cause squeaks & draw your eye to the flaw in the dashboards lines.
defrost on passenger side only? - do you mean wing wirrors? - check fuse / wiring / switch connections & element in mirror housing.
Old Nov 2, 2007 | 03:17 PM
burnhad's Avatar
The fog lights on your tailgate are controlled by the switch on your dashboard next to the driving lights switch (second from the left). But you probably already knew that.
itsbob
Jul 18, 2012 12:30 PM
booyah7
Nov 17, 2009 09:04 AM
Shadill
Nov 1, 2009 03:05 PM
Disco C
Aug 8, 2007 08:25 AM
dma3
Apr 2, 2005 02:55 AM
