P38 door locks
Old Sep 27, 2012 | 11:18 PM
georgep's Avatar
Default P38 door locks
Controlled by a RELAY or and ECU? Where is it or what is it called. Ned to order
Old Sep 28, 2012 | 04:48 PM
Rovin4life's Avatar
door locks going crazy is a sign that the driver door latch is bad.
Old Sep 30, 2012 | 09:58 PM
georgep's Avatar
That is the ONLY working that does not go off on it's own. Passenger you CAN NOT pull up on the lock it is like it is not connected to any thing but it does cycle.
Old Oct 1, 2012 | 06:13 PM
Rovin4life's Avatar
disconnect the driver door latch with the keys in the ignition and the vehicle running. the door latch on the passenger side if it works normal means the driver side is bad. if it doesn't work then its the passenger side latch.
Old Oct 2, 2012 | 09:03 AM
georgep's Avatar
Will do as soon as I figure out HOW to get the door card off without damage. Need to replace the window lift on the drivers side also, have that already.
stusanderson
Aug 5, 2012 04:33 PM
Lisa
Oct 17, 2005 10:00 PM
Lisa
Aug 8, 2005 10:31 PM
II2Go
May 30, 2005 08:31 PM
Kennydhl
Apr 18, 2005 10:54 PM
