P38 has trouble starting when hot
Old Dec 13, 2010 | 07:02 PM
bajaboss342's Avatar
3rd Gear
Default P38 has trouble starting when hot
Hello,
My 1996 P38 4.6HSE has issues starting when the engine is hot. The car starts fine in the morning when the engine is cold, but if i drive around and get the engine up to operating temps and try to start the car after 5 or 10 min i get a rough idle and sometimes the car will just die. The rough idle only lasts for about a minute and then the car will run fine.
The check engine light is also on and my OBDII reader pulls the following codes.
P1177 and P1179
Has anyone experience anything like this before that could give me an idea on how to troubleshoot this problem?
Thanks
Old Dec 13, 2010 | 09:50 PM
Rovin4life's Avatar
check fuel pressure and go from there.
Old Dec 13, 2010 | 11:02 PM
3rd Gear
I checked the fuel pressure a few weeks back and it was at 25 PSI. I replaced the fuel filter and it went up to 30 PSI.
Old Dec 14, 2010 | 12:21 AM
LRScott's Avatar
P1177:Maximum Negative FMFR Correction Fault
P1179:Maximum Negative AMFR Correction Fault
Its a fuel mixture problem. You need to find out what is causing it. Could be the fuel pump, could be the MAF, may also be the O2 sensors. You need to get a scanner on there that can read what the sensors are doing and if they are in normal their normal ranges.
Old Dec 28, 2010 | 01:05 AM
3rd Gear
Default New Fuel Pump Fixed problem
I replaced the fuel pump last week and everything is back to normal. Just thought I would post an update just incase someone else has this problem down the road. Thanks for the help everyone.
Old Dec 28, 2010 | 02:23 AM
LRScott's Avatar
Thanks for the follow up. It is interesting that your fuel pump was able to produce 25psi even though it was bad... Mine only produces 15 to 20psi but functions normally.
fem
Mar 18, 2012 11:09 AM
63gstone
Aug 30, 2010 07:34 PM
LRScott
13
Apr 7, 2010 02:26 AM
UMdiscoII
Feb 24, 2010 06:20 PM
twmj1953
Sep 29, 2009 09:49 PM
