P38 rangerover crank shaft senser not working
P38 crank shaft sensor....code
This doesn’t make too much sense to me, I ran my codes and canceled them to see if the engine check light would come back on after I drove around for a day or so, but it did not???? I am still going to replace the part because I know that they go bad after a certain amount of miles. I do all the work on my own and I was wondering there is any difference with installing this sensor compared to putting an oxygen sense in? Also i am taking the car on a 10hr drive next week and i dont know if i will get te part in time is it bad to drive with a bad one??
The code is p0335
the other codes that came up are=
p1314
p0158
p1193
The code is p0335
p1314
p0158
p1193
It is on the lower drivers side of the engine toward the rear by the bell housing of the transmission. It is probably under a cover so it may not be all that obvious. If you look on you tube you should be able to find a video of it, you may need to search for a D2 video but I am willing to bet they are similar.
Most wrecking yards will ship to you, they do not get all their business locally unless they are a pick and pull.
free classified advertising
information about pakistan
travel in pakistan
tourism in pakistan
tourism of pakistan
rent a car
rent car
renting a car
free classified
online shopping
buy online
travel in pakistan
tourism in pakistan
tourism of pakistan
rent a car
rent car
renting a car
free classified
online shopping
buy online
4x4lover
03-16-2013 08:38 PM
Benjamin Wright
02-23-2013 10:22 PM
asat
11-03-2008 09:59 PM
