P38 rangerover crank shaft senser not working
Can I just replace this or is there a procedure that I have to go through? The OBDII tester said that the unit is broken but the vehicle seems to run great, should i replace this??
This doesn’t make too much sense to me, I ran my codes and canceled them to see if the engine check light would come back on after I drove around for a day or so, but it did not???? I am still going to replace the part because I know that they go bad after a certain amount of miles. I do all the work on my own and I was wondering there is any difference with installing this sensor compared to putting an oxygen sense in? Also i am taking the car on a 10hr drive next week and i dont know if i will get te part in time is it bad to drive with a bad one??
The code is p0335
the other codes that came up are=
p1314
p0158
p1193
The code is p0335
p1314
p0158
p1193
What year is the rover? If the sensor is bad then it will either not start or it will stall out after a few minutes. I have not much issue with them on the GEMS motor but on the Bosch they fail all the time. I would at least buy one and keep it if it is Bosch just in case.
The range is a 96 4.0 whare should i get it? I normally get my parts off of rovers north but I did not find the part on there site?? The check engine light still has not come back on i am not shure whats going on
96 p38 Range
1978 Toyota FJ-40 (For Sale)
96 p38 Range
I just ordered it to be overnighted to me so that i have it when i drive south on thursday.I want to spray the bolts in advance, whare exactly id it located and also do you know of any junk yards over the internet thati could buy prts from?
It is on the lower drivers side of the engine toward the rear by the bell housing of the transmission. It is probably under a cover so it may not be all that obvious. If you look on you tube you should be able to find a video of it, you may need to search for a D2 video but I am willing to bet they are similar.
Most wrecking yards will ship to you, they do not get all their business locally unless they are a pick and pull.
free classified advertising
information about pakistan
travel in pakistan
tourism in pakistan
tourism of pakistan
rent a car
rent car
renting a car
free classified
online shopping
buy online
travel in pakistan
tourism in pakistan
tourism of pakistan
rent a car
rent car
renting a car
free classified
online shopping
buy online
4x4lover
Mar 16, 2013 08:38 PM
Benjamin Wright
Feb 23, 2013 10:22 PM
asat
Nov 3, 2008 09:59 PM
