Please Help
Old Jan 11, 2008 | 09:08 PM
jvcuevas's Avatar
6th Gear
Default Please Help
I've got a 2000 Range Rover 4.6 with 83K miles
My Service enging soon light is constantly on.. I get it reset, minutes later it back on.. I've changes the Mass Air Flow meter.. Light still stays on. I get the following error Codes
0734
p1412
p1415
any ideas?
Old Jan 12, 2008 | 09:04 AM
Default RE: Please Help
I can't find the 1412 and 1415 codes thru 3 different areas, don't know what to tell you. The new MAF should have cleared off your 4 th. gear out of ratio code.
Old Jan 12, 2008 | 09:23 AM
jvcuevas's Avatar
6th Gear
Thanks Mike.. is there a Mass Air Flow Meter and sensor? I replaced the Meter.. I saw a site selling the MAF meter and sensor as two separate items?
Old Jan 12, 2008 | 12:11 PM
The MAF is attached to the air intake tube between the air filter and the t/body. Normally it is sold as one piece, some places sell just the coil porton of it.
Old Jan 12, 2008 | 01:56 PM
raid13's Avatar
did you clear the code and reset adaptions from the transmission control module too?
resetting adaptions is very important to making the code not return.
Old Jan 12, 2008 | 05:51 PM
jvcuevas's Avatar
6th Gear
My buddy at the auto repair shop cleared the code using and ODBC Connector???? How do you reset adaptions? Do I need another tool to complete thattask??
Thanks a bunch
Old Jan 12, 2008 | 10:34 PM
raid13's Avatar
can his scan tool read engine and transmission codes? if so than he should be able to also reset adaptions.
Paul Aspen
Nov 4, 2013 02:10 PM
tarpon66
Jul 27, 2011 12:38 PM
sawadeh
Jul 2, 2011 08:10 PM
Speed racer
Oct 11, 2008 10:56 PM
