PLease Help Range Rover will not start
Old Jul 18, 2011 | 05:16 PM
Jason428sc's Avatar
Default PLease Help Range Rover will not start
Hi guys,
I just bought a 98 Range Rover SE 4.0L. I am having a problem with starting it. It turns over normal and gets fire to the plugs but will not crank. Can this be the crank position sensor if I am getting fire to the plugs?
Fuel pump seems to come on for a few seconds when turn the key to the on position. The only messages that come up on the dash are "windows not set".
Thanks.
Old Jul 18, 2011 | 07:26 PM
Rovin4life's Avatar
possible, just make sure their is power past the the inertia switch on the lower passenger side trim.
Old Jul 18, 2011 | 08:33 PM
Jason428sc's Avatar
I just checked the oil and theres water mixing with it. Blown head gasket? Would that cause it not to run?
Thanks.
Old Jul 20, 2011 | 09:13 PM
Mrmerlin's Avatar
yes a blown headgasket would let water into the cylinder i hope that you didnt try to start it in this condition as you might bend a rod and thus a new good used engine would be the recipe for repair
Old Jul 21, 2011 | 08:37 AM
Jason428sc's Avatar
Well, I did try to crank it a few times before I realized I had water in the oil. The engine was turning over a little slower than normal. I guess that maybe why it never tried to fire up??? I'm going to hopefully tear it down this weekend and see what is going on. i have ordered a new head gasket kit for it.
Jason428sc
Dec 12, 2023 05:44 PM
Seven Costanza
Jan 23, 2013 02:17 PM
rabskin1982
Jan 15, 2012 07:43 PM
MattV8i
Jun 28, 2007 07:24 PM
jonsimon
Jan 29, 2007 01:55 PM
