Power Mirror Dip
Old Mar 1, 2006 | 09:24 PM
rangeroverboi's Avatar
Default Power Mirror Dip
The Power Mirror Dip on my '97 RR 4.0 has lost its' marbles. When I select reverse, the mirrors dip as they should. When I select another gear (usually D or P), the mirrors attempt to return to their proper setting, but never seem to quite make it there. It's prominent more so on the drivers side than the passengers. I know I can turn the feature off, but I kind of like it; keeps me from running over two potted trees at the top of my driveway. Any ideas on how to fix this?
Thanks,
Brett
Old Mar 1, 2006 | 11:03 PM
05LandRover's Avatar
Default RE: Power Mirror Dip
KY lube?
lol
i dunno?
Old Mar 1, 2006 | 11:48 PM
teamyonex's Avatar
I think what you need to do is position the mirrors correctly, then save the setting, assuming you have seat/mirror/climate memory etc. I think what's happening is that they're currently just returning to a position you haven't selected. This can happen if some one manually tweaks them... they're electronically going to the setting, but are physically out of synch. This happened to my wife's car. Good luck.
Old Mar 2, 2006 | 06:18 PM
I'm going to need some KY Lube myself if this car doesn't stop bending me over.
Old May 17, 2006 | 07:10 AM
CronicJoeBlunt's Avatar
Mine are having the same problem, it is due to dirt, wear, etc. My solution was to just turn off the reverse dip function ( key on, engine off, then hold down the memoy set button for five secs with the shifter in R position)
bribake
Jun 4, 2022 03:07 AM
tw_salisbury
Mar 10, 2013 06:26 PM
wastedincome
Dec 27, 2012 10:19 AM
bentonrover
Freelander
Jan 3, 2010 02:52 PM
03discoman
Oct 29, 2009 10:47 PM
