problem with ABS pump on 91 range rover
Old Oct 10, 2005 | 01:29 PM
WVrover's Avatar
Default problem with ABS pump on 91 range rover
i've run into a problem, and i cant get a straight answer out of a mechanic. recently i had a brake job done on my truck by a local mechanic who had no idea what he was doing. the day after my rover came out of the shop, the power brakes went out and the brake pump started making a nasty noise. when i drove the truck home and turned it off, the brake pump continued to make noise. i had to disconnect the battery to get the pump to stop making noise. the alternator was bad, so i went ahead and replaced it, but the noise still persists. i spoke with several mechanics and the only thing i really found out was that i would need to replace the brake pump and need to flush and rebleed the brake system. before i go about this, is there a way to check and see if it is infact the brake pump that's acting up? would it be the brake pressure? how can i check the pressure? the brake pump is ridiculously expensive, so avoiding this replacement would be great. anyone know of a way to go about this? i've got a shop manual for the rover, but before i swap the pump out, i would like to make sure its the pump.
Old Oct 12, 2005 | 02:30 AM
bonnettoboot's Avatar
Default RE: problem with ABS pump on 91 range rover
It is fairly easy to tell if the pump is making the noise just feel it with your hand. Secondly to be sure, disconnect the plug going to the pump to see if the noise stops. It is hard to understand why the pump would continue to run with the ignition off, unless the relay was faulty) points welded together). As for the Alternator, where did that fit in to the scenario?
________
Kawasaki EL250E
Paul Grant
Jun 27, 2011 04:20 PM
dumellarah
Mar 3, 2009 07:13 PM
arky34
Feb 29, 2008 06:21 PM
barranr
Jun 3, 2007 06:36 AM
cottonpatchweims
Jan 14, 2005 01:59 AM
